Re: WP34s Flash Question Message #17 Posted by Cristian Arezzini on 18 June 2012, 12:15 p.m., in response to message #1 by rgray
Hi rgray, I use Mysamba without problems under Linux with Wine, but there are two things I had to do to make it work:
- Create a symlink in Wine's dosdevices folder, which I called com1 and which points to the actual port (in your case I suppose "/dev/ttyS0);
- Give my regular user the permission to use modems (as on my system, that port is seen as a modem).
After that, I can simply run MySamba, type com1 in the port field, and it just works.
HTH,
Cristian
