Re: USB-41->NoV-64/Clonix-D compatibility Message #5 Posted by Diego Diaz. on 14 June 2012, 6:18 p.m., in response to message #3 by Les Wright
Hi all,
Thanks for your kind words Marwan. Of course you're welcome to include Clonix-D and USB-41 among your HP-41 gear... just mail me at your best convenience.
Note however that USB-41 may take a while since first batch (20 units) was sold-out, but be sure more will come... :-)
You're right Les, Clonix-D is poorly documented except, may be, for the Comparative Chart pointed out by Marwan (Thanks BTW... ;-) and a small note in the ClonixConfig manual.
Its concept is so simple that it is very little what I can add to these references, just summarize that is it a Double sized Clonix-41 module (12 pages instead of 6) which can act like if they were two different Clonix's depending on the port it is plugged into.
Since it's built using the same processor used in NoV-46 and USB-41 modules, it can also share some of the configuration options of these "big brothers" with inherent limitations since Clonix-D is an "only-ROM module".
NoV-2E7 is (was) a 128K RAM project. Natural succession after NoV-64 (hence its name: 2E7=128). Two prototypes were built and they work as expected. Regrettably the RAM chips required to build this module were early retired from production by the manufacturer due to a high rate of failure at silicon waffer level. So, for now, it's a dead end, let's see if a compatible (and reliable) RAM chip appears in the future... :-)
Best wishes from Tropic of Cancer.
Diego.
PS. Les, Checked yesterday with my friend, your shipment arrived in good shape last week. Thanks and again my apologies for the inconveniences with your first programmer.
