Rechargeable 2/3 AAAs in 41C-series Message #1 Posted by Les Wright on 13 June 2012, 7:41 p.m.
Inspired by this recent thread, I acquired eight 350 mAh 2/3 AAA batteries quite cheaply on TAS. Actually, they started out life as 9.6V battery pack for a radio controlled plane, but it was a simple enough matter to harvest the eight flat-top cells from the pack.
As reported by Luiz in that thread, they are about the same length as N cells, but a bit narrower. They work fine in the calcs, but the only glitch I have encountered is that occasionally the positive-end button doesn't make adequate contact with the spring tip in the holder, and I have to line it up just so before reinserting the lot into the calculator. I have been testing things out with some pretty heavy use of my card reader, which draws batteries more so than any other peripheral I have, and things are going strong--not even a flicker of the BAT indicator or objections from the card reader.
I am waiting on a bunch of AAA-to-AA converter sleeves (see here) to aid in charging. I intend to make up the centimetre or so space in the holders with springs or little balls of foil. In the meantime, I charged the cells successfully in my very good LaCrosse charger. The cells fit width-wise in the AAA grooves (of course), and I made up the space with little foil cylinders. This is NOT the best way to charge these cells--the lowest current the LaCrosse offers is 200 mA, which is fine for AAs of over 2000 mAh capacity, but is a little steep for cells in the 200-400 mAh range. That said, I initially discharged and charged the cells fully before use, and even at that high current they didn't get warm. Of course, I paid close attention--I have cooked a few NiMH AAs in my day in so-called rapid chargers, so I have learned my lesson. That said, fashioning some PCB resistors like Luiz suggests to cut the current and lengthen the charging time seems wise.
Just thought I would share this info with anyone interested. I am looking at the CL upgrade for my CV. The CL puts a higher draw on batteries. I hate chewing up alkalines, so it will be interesting to see if this is a viable way of keeping powered up.
Edited: 14 June 2012, 4:01 p.m. after one or more responses were posted
