41CV from craigslist Message #1 Posted by David Persinger (US) on 12 June 2012, 11:06 p.m.
I have my first opportunity for some vintage calculator restoration...
I saw a 41CV advertised on Craigslist for $50. When I went to get it I saw the contacts were corroded. I removed the corrosion I could but it would not power up with new batteries. I bought it for $20, thinking maybe I could get it working somehow.
The foil is corroded back to the connector on one side but the contacts to the main board themselves look good.
what is the best way to get this fixed? Find another non-working donor which has no corrosion and swap out the back? Solder a wire from the connector to the battery compartment? Or is there a way to repair the foil on this one?
I know there is some info in other threads, but I find it terribly difficult to search the forum.
I appreciate any advice on this...
