USB41 + 41CL connection to PC (for Linux/Mac). Here goes: Message #1 Posted by Geir Isene on 12 June 2012, 8:37 a.m.
So, it's done. Thanks for all the input.
From the website:
Program to facilitate connection between an HP-41 and a PC running Linux/Unix/Mac OSX.
With this program and the USB41 module, you can use your PC as a printer for the HP-41. USB41 module by Diego Diaz: http://www.clonix.org
With this program and the serial interface to the HP-41CL replacement board, you can transfer data/modules between a PC and an HP-41. HP-41CL by Monte Dalrymple: http://www.systemyde.com
SYNOPSIS:
pc41 [DEVICE] [OPTION]
DEVICE:
d=devicename
Specifies the device name for the connection from the PC.
OPTIONS:
-h
Displays the helpfile
r=filename
Read data from the HP-41 and save to "filename" (9600 baud)
w=filename
Writes "filename" from the PC to the HP-41 (4800 baud)
Make sure the program is "runable" (with "chmod a+x") and drop it in your "bin" folder of choice and you are ready to go.
The program must be run as root to get access to the serial/usb port.
The program defaults to input from /dev/ttyUSB0, but you may specify another input device by simply adding it as an argument to the program:
pc41 d=/dev/ttyUSB1
Default usage is with the USB41 module. To use the program to transfer data/modules using the HP-41, you need to provide one of two options:
pc41 r=filename
pc41 w=filename
With the option "r=filename", you READ data FROM the HP-41 and save it in the file specified by "filename".
With the option "w=filename", you WRITE data from the file specified by "filename" TO the HP-41.
Without the "r=" or "w=" options, the program expects input from an HP-41 with the USB41 module and acts as a printer.
Any printing from your HP-41 will go to Standard Out. To print whatever comes from the HP-41 straight onto the screen, simply run the program:
pc41
You can of course do all kinds of tricks on the PC side like piping the output or redirect it to a file, etc.
To print a program on the HP-41 to the file "myprogram.txt" on the PC, do:
pc41 > myprogram.txt
Except for ending the program with a "Control-C" on the PC, you may also print the message "PREND", and the program will terminate (just enter "PREND" into Alpha and do XEQ"PRA")
You must have Ruby installed as well as "ruby-serialport" (on Ubuntu or Debian, do "sudo apt-get install ruby-serialport"). Alternatively you may install ruby-serialport from RubyGems:
sudo gem install ruby-serialport
The script will work just the same.
For Mac OS/X users, the usual device would be "/dev/tty.usbserial ". To write the file "~/coolstuff.txt" from a Mac OSX computer to the HP-41CL using the serial connector:
pc41 d=/dev/tty.usbserial w=~/coolstuff.txt
Version: 0.2 (2012-06-12)
License: Public domain
Here is the pc41 program.
Edited: 12 June 2012, 8:38 a.m.
