Re: 41CL: Linux/Mac connection solution (soon) Message #25 Posted by Raymond Wiker on 10 June 2012, 3:30 a.m., in response to message #24 by Geir Isene
I did some testing yesterday, mainly to find out whether I had a broken serial cable. On my MacBook Pro, I was able to transfer from the 41CL by doing something like
(stty 9600 cs8 -parenb -cstopb raw; cat) < /dev/cu.PL2303-00002006 > capture.96
where cs8 means 8-bit data, -parenb means no parity, -cstopb means 1 stop bit,and raw means to pass the data through unchanged (instead of mucking about with CR/LF characters etc). I would then run YEXP on the calculator, and hit Ctrl-C on the computer when the calculator finished exporting.
Prior to this, I tested using minicom, but got incorrect results. This was probably because minicom changed the line endings (and possibly also other things), and also stripping away null bytes.
Note that the command above does not do byte-swapping; one possible way of doing this is something like
dd if=infile of=outfile conv=swab
So, to summarize:
Transferring data from the 41CL works fine under OSX at least, but the details of the setup needs to be exactly right. I also found that I needed to do SERINI followed by BAUD96 if the calculator had been power off (still on YFNS 1E, so this may not be necessary on newer units.)
Oh, and this was all at TURBO50 - there is no excuse for a relatively modern computer not to be able to keep up with a 9600 baud serial stream :-)
