Re: Working around broken Spice battery connections Message #4 Posted by Les Wright on 5 June 2012, 12:18 a.m., in response to message #3 by Katie Wasserman
Katie, I don't see a working link.
Canadians can't order from Amazon.com. Amazon.ca offers a different spectrum of products, and not this. I am sure I can find something similar here.
Can you comment on the specs of the little screws. Size? I am assuming they are also made of a conductive material.
I thank you for this. I really want a more enduring fix for those contacts. I am concerned that just cramming little bits of aluminum foil puts undue strain on that circuit board and something will give way. Moreover, I worry that loose foil bits could short the battery and kill it or even do something worse.
I'll look for beryllium copper and little screws this week.
Les
