Re: Very OT--What is a TI N-Spire? Message #8 Posted by fhub on 1 June 2012, 5:56 p.m., in response to message #7 by Namir
I will set a asied a room in my house as a shrine in your honor.
Ok Namir, you can start setting up this room! ;-)
But it would be too much honour for me, I neither wrote the emulator nor the GUI, I've just put everything together to make it simple run. (ok, I was involved a bit in improving and bugfixing the GUI, but that's not worth to mention).
Unfortunately the Nspire ROM-image file is a bit too large (23MB) for me to upload with my slow internet connection, so you have to download 2 files: my file with the GUI+emulator and this ROM file.
Here are the detailed instructions what you have to do:
1) download and unpack the emulator package 'NspireCX.zip':
http://www.spaadyshare.net/65t1os8as96b/NspireCX.zip
2) download the Nspire ROM images:
http://webgel.net/bb/files/nspire_emu_easy.zip
3) from this nspire_emu_easy.zip unpack the 2 files 'boot1_cx.img' and 'flash_cx.bin' from the subfolder 'bin' and copy them into your just created folder NspireCX
4) run the file 'Install.bat' (only needed the very first time)
5) now you can run either 'CX_horizontal.bat' (horizontal layout e.g. for Netbooks) or 'CX_vertical.bat' (original layout) - the second one has a small glitch: after the Nspire-ROM has been loaded you must first click with the mouse anywhere on the desktop and then click again in the emulator window, only then its keyboard is working.
I prefer the CX_horiziontal version, because this one is newer and has more features (better key assigments, cursor on the touchpad works in all 8 directions, ...) and because of its horizontal layout it can also be used on netbooks (with 1024x600 screen), but of course you can try both.
For the CX_vertical don't forget the remark in point 5) above (clicking at the desktop first).
Now have fun with this emulator - but be prepared to get some headaches, because the TI-Nspire is indeed not really easy to use.
(I definitely love my TI-92+ much more!)
Franz
PS: Here's a small introduction with the basic steps for using the TI-Nspire CAS:
http://covenantchristian.org/bird/TTT/TI-NspireCASprimer.pdf
And of course you can download the full NspireCX-CAS manuals from the TI-website.
Edited: 1 June 2012, 7:25 p.m.
