Caveat for VERSION three 41CL users Message #5 Posted by Geoff Quickfall on 29 May 2012, 12:36 p.m., in response to message #1 by John Abbott (S. Africa)
Hi John,
Sorry for the mix up between the versions. As a beta user I created YCTOF for the CL ver. 1
As you now know (unfortunately) YCTOF must be modified for version 3. I must admit that I have not updated YCTOF too reflect Montes changes with the addition of even more ROM images which now occupy the free user RAM on version 1. It would appear that you overwrote ISENE ROM if you only used the OC9 as a backup.
Now a CLONIX could be used to replace the image or the serial. I have not been using the serial or playing much with the CL for a while as home life is extremely busy. If you do get the serial to work would you mind posting a step by step set of instructions including the software used and your operating system.
I am not in possession of a ver. 3 so this was a surprise.
So a caveat for all you CL users with version 3. YCTOF program must be modified to reflect the free user RAM available on your version:
Example:
Version 1. OC9 is free for use and of course check the manual.
Version 3. 118 appears to be the first 'user RAM' that is available for a flash backup.
I guess I need to get version 3! I am thinking that Monte would be able to send you a copy of the ROM images complete with the labels as they appear in the CL version three. Try emailing him directly.
Cheers, Geoff
Edited: 29 May 2012, 12:39 p.m.
