Re: Link for SAMBA v2.10 download Message #6 Posted by Tom Sauntry on 27 May 2012, 5:37 a.m., in response to message #5 by Marcus von Cube, Germany
I have tried Mysamba with no success.
This was my first attempt at flashing my WP34S to load the new 3.1 image. I am using Windows 7 and I tried SAMBA 2.11 since it was targeted for Windows 7. I am using Eric's cable with an FTDI adapter. After installing the FTDI drivers and a few atttempts at finding the right keystrokes and ERASE RESET commands to prep the HP-30B I got it to connect. I pointed SAMBA at the correct file and selected the proper board. When I tried to send the file, the dialog box indicated only 1% of the file transferred and it showed "NO BOARD" on the bottom right of the box. Evidently, I could not get SAMBA to recognize the board or to accept the setting for the board.
Since then I cannot get anything to connect to the calculator. I have tried Mysamba (with XP SP2 compatibility), and now SAMBA 2.10 with no luck. I have installed new batteries and checked that Windows show the drivers. The blue lights on the cable do blink a few times, but all I get is connect failed messages.
So, I have a dead HP-30B and can't get it flashed.
Thanks
