Re: USB support for the 48GX? Message #4 Posted by Raymond Del Tondo on 25 May 2012, 11:18 p.m., in response to message #1 by Matt Agajanian
there exist several simple solutions for connecting an HP-48GX to a PC through USB using a serial-2-USB converter.
I use a Sitecom CN-116 with a normal HP serial cable, and the custom made USB cable from teknovo also works well.
These days, you can even hook up an HP-41 to a PC via USB using a PIL Box, thanks to J.F. Garnier and Christoph Giesselink:-)
HTH
Ray
