Re: HP 34S Cable to Flash 30b Message #9 Posted by Harald on 24 May 2012, 5:49 p.m., in response to message #8 by David Griffith
Yay! Do these boards include the extra functionality of charger and/or IR emitter?
I have experimented with several versions of it.
One includes Li-Ion battery handling, so the calculator is charged via USB and one of the CR2032s acts as memory backup. Then there is a "basic" version which includes nothing but the USB connection for flashing. The 3rd version (the one I have just received the PCBs for) runs the calculator on USB power while it is pluged in, saving (but not recharging) the CR2032s. It also includes the resistor for the IR diode. The IR diode itself is not on the PCB though, as that would make assembly of the calculator awkward and would also require very exact drilling of the hole for the diode.
I have also made a PCB to convert the HP-flash-cable from RS232 to USB.
See also this post .
I will hopefully manage to post pictures this weekend. Progress has been slow as I have been too busy at work.
Cheers,
Harald
