Re: [WP34S] "Memory Leak" in Integrator? Message #3 Posted by Les Wright on 15 May 2012, 4:03 a.m., in response to message #2 by Paul Dale
When you restart, the stack should be cleared (if you start with an XEQ, not with R/S).
Yup, that does it. If I run the program I am attempting to integrate with XEQ, passing it a valid argument, the claimed RAM goes back to the heap and the next time I run integrate it works properly. However, if I DON'T do this after interrupting an integration with R/S or EXIT, the integrator may not behave well--for example, if the display just shows "Running Program" instead of the integral sign = interim results, I know that something is not going well.
Les
