Re: How "Green"? Message #9 Posted by Crawl on 7 May 2012, 6:49 a.m., in response to message #8 by Maximilian Hohmann
Yeah, I haven't had too much problem with solar calculators. Ones that are totally solar powered usually work pretty well; I've had some from TI that could work at night under a street light.
I've had different experiences with dual powered solar calculators. Of course, they have a battery, too (and which seems to last a very long time), so normally they don't need to work with only light, but on the other hand they have smaller solar cells so they work less well than solar-only calculators when they battery dies.
I had a Casio dual-powered calculator that I removed the battery from to see how well it worked in low light, and the answer was "not that great". But I've had my Sharp 506w long enough that its battery died once, so I tried using it solar-only in that time. It seemed to work in reasonably low light, *except* that doing an integral in low light would cause the display to blank off and the calculator to reset. This calculator's statistics functions are also quirky: Rather than keeping a running sum of certain parameters as you enter data, it calculates it all at once after entering data only after you ask for some statistics result (ie, the mean). In office light, it could handle 63 data points, but more than that would also cause it to reset. If it was "smart" enough to throttle its performance in low light, it could probably do anything.
