Re: Flashing of WP34S, entering SamBa via keyboard Message #3 Posted by Harald on 5 May 2012, 2:01 p.m., in response to message #2 by Marcus von Cube, Germany
What do you do after flashing? Reset and then ON?
Or am I making a mistake here?
I am beginning to think my adaptor is at fault. I just don't see how, as it works if I use the erase button instead of ON+D, ON+S+S.
I am probably looking at the problem from the wrong angle.....
How the heck can MySamBa transmit the data and the calculator NOT contain the firmware afterwards? If MySamBa is happy, that means the calculator MUST have given the correct reply, therefore it MUST also have entered the bootloader. So would you agree the problem must lie in something that happens after flashing? What does happen after flashing? Anything that could go wrong there?
Sorry to bother you with this, I just don't seem to be able to work out what is going wrong on my own....
Cheers,
Harald
