Re: Thank you, Geoff Quickfall Message #5 Posted by M. Joury on 3 May 2012, 3:40 p.m., in response to message #4 by Ángel Martin
There are a couple of other possible limitations. Beyond "Having a square cornered display" here is the relevant section from the V3 manual:
Hewlett-Packard changed the display driver circuitry in the 41 series during production,
and this change affected one component value on the CPU circuit board. The 41CL circuit
board implements the component value used in later production units. Units with the correct
display driver can be identified as follows:
• If your 41C (not CV or CX) has a serial number starting with “1954” or larger it uses
the correct display driver.
• If your 41CV/CX has a serial number starting with “2003” or larger it uses the correct
display driver.
It is theoretically possible to use the 41CL circuit board with the older display driver, but
this requires soldering an extra capacitor to either the 41CL circuit board or to the calculator
main board. If you really want to upgrade a calculator that uses the older display
driver, please contact us directly for details.
In addition to the display driver change, Hewlett-Packard also experimented with a different
method of connecting the CPU board to the main board. Unfortunately it is not possible
to identify units that used this different connection method via the serial number.
I hope it is ok to post this here.
Cheers,
-Marwan
