[WP-34s] can't flash with calc_ir.bin Message #1 Posted by Alexander Oestert on 3 May 2012, 5:08 a.m.
I'm preparing my WP-34s for crystal and IR. In order to do so, I thought it best to flash it with IR-enabled firmware beforehand. I use SAM-BA 2.10, always do the whole ERASE procedure before flashing.
I tried calc_ir_full.bin 2935, calc_ir_full.bin 2931 and calc_ir.bin 2918 - no success. SAM-BA seems to do its transmitting work properly, but the WP-34s doesn't turn on afterwards.
Before, I had calc_full.bin V3 2781 on the machine, I re-flashed the calc with this version in between the IR-firmware tries and afterwards and it always worked.
EDIT: The same result with MySamba: no flashing with IR firmware, ok flashing with 'normal' calc_full.bin 2781.
Any ideas and suggestions are welcome!
Edited: 3 May 2012, 5:36 a.m.
