Re: [WP34S] Curious Bug in Inverse Normal Function Message #60 Posted by Dieter on 3 May 2012, 4:08 p.m., in response to message #59 by Paul Dale
Pauli, Les et al. -
I'll try to summarize all this in one single post. ;-)
Yesterday I replaced the initial rational approximation from by previous suggestion by a dedicated version for p down to 1E-400. It now provides an estimate with an absolute error near +/- 0,002 and requires just two short real constants. The rest can be done with INC commands. ;-)
Estimate for 1E-400 =< p =< 0.5:
r = sqrt(-2 ln p)
x = r - (0,295*(r+1) + 2) / ((0,0511*r + 1) * r) + 1)
An estimate x below 0.001 should get rounded to zero to ensure best results in the following correction step. The approximation was designed to give eight valid digits after the first iteration (max. error approx. +/- 2 units in the 9th digit), and with a second resp. third iteration we should be on the safe side for standard resp. double precision - as long as the working precision is sufficient. But that's another story - see my other remarks below.
Here's my implementation for the 34s.
001 **LBL A
002 STO 00 // save p in R00
003 ENTER[^]
004 DEC X
005 +/-
006 MIN
007 STO 01 // q = min(p, 1-p) in R01
008 LN
009 STO+ X
010 +/-
011 [sqrt] // r = sqrt(-2 ln q)
012 ENTER[^]
013 INC X // rational approximation starts here
014 .
015 2
016 9
017 5
018 [times]
019 INC X
020 INC X
021 .
022 0
023 5
024 1
025 1
026 RCL[times] Z
027 INC X
028 RCL[times] Z
029 INC X
030 /
031 - // first extimate x
032 ENTER[^]
033 SDL 003
034 x<1? // x < 0,001? resp. 1000 x < 1 ?
035 CLSTK // then x = 0
036 DROP
037 STO 02 // save x in R02
038 2
039 DBL?
040 INC X // 2 resp. 3 iterations will do
041 STO 03 // loop counter in R03
042 **LBL 000
043 RCL 02
044 +/-
045 [PHI](x) // Q(x) = right hand integral = Phi(-x)
046 RCL- 01
047 RCL 02
048 [phi](x)
049 / // t = (CDF(x) - q) / PDF(x)
050 FILL // save t on stack
051 x[^3]
052 6
053 / // least correction term is t^3 / 6...
054 RCL 02
055 x[^2]
056 STO+ X
057 INC X
058 [times] // ... * (2 x^2 + 1)
059 x[<->] Y
060 x[^2] // second last term is...
061 RCL[times] 02
062 2
063 / // ... t^2 * x / 2
064 + // add two smallest terms together
065 + // add this to t to get complete delta
066 STO+ 02 // correct x by delta
067 DSZ 03
068 GTO 000 // repeat 2 or 3 times
069 RCL 00
070 .
071 5
072 -
073 SIGN // finally adjust sign of x
074 RCL[times] 02
075 END
0,0025 [A] -2,8070 33768 34380 41172 21810 39471 2269 E+0 exact
This works fine at least for quantiles >= 1. Now let's look at p close to 0,5.
Note: "+1D34" = +1 unit in the 34th significant digit.
0,49 [A] -2,5068 90825 87110 35762 36343 18346 9043 E-2 +1D34
0,4999 [A] -2,5066 28300 88035 09892 06501 05407 8430 E-4 +1D32
0,4999999 [A] -2,5066 28274 63102 67517 65674 82243 4196 E-7 -3D29
0,4999999999 [A] -2,5066 28274 63100 05024 42013 42148 8860 E-10 -1D25
0,4999999999999999 [A] -2,5066 28274 63100 05029 49753 49666 4200 E-16 +5D20
This shows the problem Les and I have been talking about previously. Generally spoken, our basic approach (i.e. evaluate the CDF for the current approximation, see how good it matches p and apply a correction) is good for up to 34 decimals, but not for 34 significant digits. This is because close to zero there are numerous n-digit quantiles that return the desired p so that no further correction is applied. In other words, a calculated quantile near zero with a magnitude of 10^-n may be off in its last n digits, so that we may expect something like 34-n digit accuracy. Yes, the given examples are one digit better. ;-)
What can we do? We will have to handle p close to 0,5 separately. This can be accomplished in several ways:
But there's also another way to address this issue: Forget about 34-digit accuracy. There simply is no way to ensure a valid n-digit result as long as all calculations carry just the same n digits and no further guard digits. I remember how I tried to get an exact 10-digit result for the Normal quantile on the 41C with the same 10 digits working precision. It's simply not possible (at least I do not know of a method to accomplish this). That's why I designed the algorithm I suggested a few days ago - it returns 11 good digits over the 41C's working range as long as the calculation is done with a few more guard digits, e.g. in machine code.
If I remember correctly, the original idea behind the double precision mode was this: enable the user to write user-code functions with lots of extended precision, so that the final result can be assumed to carry at least the usual 16 digits that are normally returned to the user. Once again: in many, if not most cases it's simply not possible to get a true 34-digit result unless the working precision exceeds these 34 digits. So we cannot expect 34 digits anyway. What is possible? 32? 30? 25? It depends. Round it to 16 digits and you are on the safe side. :-)
Dieter
