Re: WP 34S Printing Message #12 Posted by Harald on 28 Apr 2012, 7:00 p.m., in response to message #11 by Marcus von Cube, Germany
Hi Marcus,
I have tried two different ways of flashing. One works, and the other one doesn't. Both use my integrated USB adaptor to connect the PC to the 34S. Using ON+D, ON+S+S, reset, ON, then flashing, reset, ON results in the calculator displaying "restored" and the firmware NOT being updated. However MySamba transmits and tells me it took 24s (as usual) Following these instructions:
Hold down the ERASE button on the cable (do not release it).
Press and release the RESET button on the cable.
Press and release ON/CE on the calculator to turn it on again.
Release the ERASE button on the cable that you pressed a few steps earlier.
Press and release ON/CE on the calculator. It will not appear to turn on.
followed by flashing with MySamba (again tells me it took 24 seconds) is succesfull. After reseting and turning on the calculator it comes up displaying "erased" and contains the new firmware.
I suspect I am making a mistake in my ON+D, ON+S*S.... procedure, but can't see it. This has worked for me in the past. Am I missing a step?!? If not, the only thing that is different is the firmware.
It is almost as if the SAMBA bootloader is active, but just dicards the data instead of writing it to flash.
