Re: [OT] Sharp PC-1212 and CE-121 Message #4 Posted by Bill (Smithville, NJ) on 27 Apr 2012, 10:08 a.m., in response to message #2 by Marcus von Cube, Germany
Marcus,
Thanks for posting the link to your CAS I/O utilities. I wasn't aware of them. Nice work.
Alexander,
Please see the following link for I/O utilities for the Sharp computers:
SHARP PC I/O Programs
These work great. You want to save to a WAV mono file. The wav file should be mono, 8 bit 11 KHz or better. I use an old version of Cooledit to record/manipulate audio files. I usually just save in stereo to the PC (only one channel has data) and then just kill the dead channel using the software. Be sure you have a very clean signal and are not clipping.
If you need a sample of what the waveform should look like, then use the BAS2WAV converter to transform a basic text file into a wav file.
Bill
Edited: 27 Apr 2012, 10:09 a.m.
