(edited) Re: Difference between new HP-49G+ and HP-50G Message #2 Posted by Luiz C. Vieira (Brazil) on 25 Apr 2012, 5:20 a.m., in response to message #1 by x34
Hi, x34. Have a name? 8^)
Two obvious ones: the HP50G uses four AAA instead of the three ones used by the HP49G+, and the HP50G has an extra serial interface.
In terms of O.S., both may be loaded with the same version SO their hardware is compatible. Because they use a different ddp (sorry for that; I was reasoning in Portuguese terminology. ddp stands for electrical potential difference), I'd not risk telling they are the same inside.
Others will surely point out some not obvious differences.
Cheers.
Luiz (Brazil)
Edited: 26 Apr 2012, 3:57 p.m. after one or more responses were posted
