Re: HP-50G Matrix/Equation Editing UPDATED Message #19 Posted by Matt Agajanian on 24 Apr 2012, 11:20 a.m., in response to message #1 by Matt Agajanian
Hi all.
Thanks for all your time and effort. I'm going to see if it was some misstep on my part--system flag setting, mode switch or equation entry mishap.
But, I do recall, someone here mentioning that if the entry mode is 'Algebraic' and not RPN, that affects why the Equation Writer does not launch when the down arrow is pressed on an expressuin in Level 1. Right?
So, I'm just going to start all over again to see if the glitch happens again. If I get a quotation mark delimiter, I'll make several copies on the stack and put the thing in a variable. That way, I can get the TYPE and do whatever other techniques you suggested.
**UPDATE
I just tried my Equation Editor project again. This time, I see my equation in true form and when I press the down arrow, the Equation Writer launches allowing me to edit my equation.
Not certain what step I slipped on the last time. In any case, all is well and thanks for your very generous help.
Edited: 24 Apr 2012, 7:28 p.m.
