[WP34S] VIEWalpha not working as documented Message #1 Posted by Les Wright on 16 Apr 2012, 9:13 p.m.
On p. 73 of the most recent manual, the function in question has three documented paths to invocation. Of the three, only the second, via a function in the P.FCN menu, can I find. The first path (h VIEW alpha) merely displays VIEW s_. The third path, via a function in X.FCN, does not exist--the functions go from VERS to WDAY in the menu listing.
Is the calculator wrong, or is the manual? I am using the most recent firmware release, 2809.
TIA,
Les
