HP Forum Archive 21
[WP34S] Bug in Inverse CDF for F-distribution
Message #1 Posted by Les Wright on 15 Apr 2012, 6:08 a.m.
It takes a seemingly long time but
F^-1(0.95, 5, 10)
eventually returns the correct result of roughly 3.3258.
Regrettably, the reciprocal problem of
F^-1(0.05, 10, 5)
should return the related result of roughly 1/3.3258 ~= 0.300676, but instead, after a few seconds, we get a Domain Error.
I played around with a few more smallish probabilities and I see the same thing.
This doesn't seem to be correct. I am guessing that the initial guess of the quantile is negative, and when this is fed to the Newton refiner it spits it out because it computes the F statistic with a negative estimated quantile upon which it chokes.
Any clues? This is obviously an error that should be trapped.
Les
Re: [WP34S] Bug in Inverse CDF for F-distribution
Message #2 Posted by Paul Dale on 15 Apr 2012, 6:31 a.m.,
in response to message #1 by Les Wright
Your guess is wrong. The initial estimate is 4.754601... which isn't very close but isn't negative. The Netwon steps seem to be converging for the first couple (1.1886504 & 0.000011886) but then it diverges and errors out somewhere.....
I'll have a look into this and see if I can figure out what is going awry.
At least it isn't giving an incorrect answer :-)
- Pauli
Message #3 Posted by Dieter on 15 Apr 2012, 12:20 p.m.,
in response to message #2 by Paul Dale
Well, it is very close - if n1 and n2 get swapped. In this case the correct quantile is 4,735063... ;-)
For further details see my other posts in this thread.
Dieter
Edited: 15 Apr 2012, 12:21 p.m.
Message #4 Posted by Dieter on 15 Apr 2012, 2:22 p.m.,
For the record, here's the method I used for the initial guess. I cannot remember I did any tests on this, so use at your own risk. ;-)
In VBA it looks like this. First, there's the known initial approximation for the normal quantile. The 0.2/u term in the longest line may be replaced by 1/u^2.
Function z_guess(p)
Const root2pi = 2.506628274631
If p < 0.5 Then q = p Else q = 1 - p
If q > 0.2 Then
  u = root2pi * (0.5 - q)
  z = u + u ^ 3 / 6
Else
  u = -2 * Log(q)
  z = Sqr(-2 * Log(q * root2pi * Sqr(u - 1))) + 0.2 / u
End If
If p < 0.5 Then z = -z
z_guess = z
End Function
The F guess then is evaluated as follows. Here, p can be used the way Les did.
Function f_guess(p, n1, n2)
r1 = 1 / (n1 - 1)
r2 = 1 / (n2 - 1)
h = 2 / (r1 + r2)
x = z_guess(p)
k = (x * x - 3) / 6
w = x * Sqr(h + k) / h - (r1 - r2) * (k + 5 / 6 - 2 / 3 / h)
f_guess = Exp(2 * w)
End Function
Here, f_guess(0.95, 5, 10) returns 3.303908... and f_guess(0.05, 10, 5) gives 0,3026718... In both cases, the correct 16-digit result is obtained after just four iterations.
Dieter
Message #5 Posted by Paul Dale on 15 Apr 2012, 6:21 p.m.,
in response to message #4 by Dieter
Yes, the initial approximation is off. On the "w =" line the sign of x was wrong resulting in much badness. Fixing this results in the same initial estimates as you're getting which are much closer to the actual result -- this distribution should speed up now.
I'm going to leave the newly added bisection guard in place, it won't cost any noticeable time if it isn't needed and it should help prevent any bad cases from wandering around aimlessly.
I already had a step size guard in place and this was obscuring the issue a bit, the jump back up was really a jump out to towards infinity but it was being curtailed to something more reasonable.
- Pauli
Message #6 Posted by Paul Dale on 15 Apr 2012, 6:38 a.m.,
I know what is happening now. The newton step is oscillating between a pair of values and the solver is giving up because the estimate gets worse not better.
Now to figure out how to fix this....
- Pauli
Message #7 Posted by Paul Dale on 15 Apr 2012, 7:39 a.m.,
Figured it out. I've modified the Newton solver to try bisection steps instead of Newton steps if things go badly. This seems to address the reported problem and will hopefully address many similar cases.
A Domain Error will still be raised if the search fails but I'd hope this is a lot less likely than before.
You'll have to wait for Marcus or Pascal to build new images/emulators.
- Pauli
Message #8 Posted by Dieter on 15 Apr 2012, 9:53 a.m.,
in response to message #7 by Paul Dale
Pauli,
I am not sure how the F quantile function finally was implemented, and for this distribution I only found some tests for an initial guess. However, my results are different. Please note that the probability here is given by q = 1-p instead of p. This is also important because the F guess may include the guess for the normal quantile which has to carry the correct sign here!
Here are my results:
 q = 0.05, n1 =  5, n2 = 10  =>  f_guess = 3.30
 q = 0.95, n1 = 10, n2 =  5  =>  f_guess = 0.30  (= 1/3.30)
That's quite close to the exact value, isn't it ?-)
Regarding the divergent Newton steps: you may want to check if the CDF returns results with sufficient accuracy. Then, I remember we had a discussion on a similar problem with another distribution. The simple and effective solution was limiting the correction to a maximum possible amount. Which here could be the correction applied in the previous iteration.
Addendum: I wrote a short program for the 34s emulator and tried the given example (0.05; 10; 5) with the initial guess based on the wrong probability 1-p (iteration starts at 4,7 or 3,3 instead of 0.2 or 0.3). The program threw exactly the same domain error as it tried to evaluate the PDF for a large negative x. ;-)
Then I tried the example with the correct initial guess 0.30 and the iteration converged to 34 digits (DBLON) within 5 or 6 Newton steps. :-)
Maybe we tracked down the error. If we did, the whole F quantile should even get evaluated faster than before. Pauli, please check how the current implementation works if you replace 0.95 by 0.05 and vice versa and/or n1 and n2 are swapped. Also the guess for the normal quantile has to carry the correct sign.
Dieter
Edited: 15 Apr 2012, 12:26 p.m.
Message #9 Posted by Les Wright on 16 Apr 2012, 1:10 a.m.,
in response to message #8 by Dieter
Dieter, this could explain why F^-1(p) on the calc seems so slow when it doesn't throw an error--there is a poor initial estimate of the quantile due to a parameter mix-up, and the Newton refiner has to run several more times to find the result, if it can find it at all.
It looks to me that the F-distribution is implemented as a special case of the incomplete beta function, which is computed via its continued fraction. Even still, F(3.3,5,10) is returned in under a second, and the corresponding PDF is even faster than that. If the inverse CDF requires an initial estimate that takes at most a couple of seconds and at most 4 Newton refinements that each compute an F CDF and PDF, the result should take 10 to 15 seconds at most not the painful 30 seconds or so that I was seeing. I experimented a lot too with the inverse t and chi-square routines, and though they took their time at times, they tended to return a result quickly. So the inverse F stood out.
I am glad for my decade-long obsession with the special functions and their statistical relatives, and was able to catch this.
Les
Message #10 Posted by Paul Dale on 16 Apr 2012, 1:39 a.m.,
in response to message #9 by Les Wright
Yeah, these function and especially their inverses are quite slow. The Newton solver hides inefficiencies like a poor initial estimate all too well.
Hopefully better now or at least once the next build gets done.
- Pauli
Message #11 Posted by Les Wright on 16 Apr 2012, 2:32 a.m.,
Dieter, Pauli, Walter, etc.,
Just deleted a longish post where I declared that the F CDF was not of full accuracy since the incomplete beta on which it relies was of not full accuracy.
I was misreading the extended display of my calc and on double checking my results the wp34s 34-digit output for F(3.3,5,10) is off only 1ULP vis-à-vis the Mathematica result. F(0.3,10,5) is off by 5ULP in the 34th digit, but that still isn't too bad given the several places in the code where full internal 39-digit accuracy can be compromised. I would expect that this accuracy is plenty good enough for the Newton solver if the convergence criterion is something reasonable--say a relative error less than 1e-32 as we see in some of the other code.
If anyone saw my misleading original post, please disregard it.
Les
Message #12 Posted by Paul Dale on 16 Apr 2012, 2:54 a.m.,
in response to message #11 by Les Wright
This level of accuracy isn't guaranteed.
The Newton step solver terminates the search once the relative error between the previous and current terms is less than 1e-24. The extra digits you are seeing are a result of the rapid convergence once it locks on to the solution.
I'll note that: we make absolutely no guarantees about the accuracy of anything in double precision mode, beyond "at least as good as single precision". In single precision, on the other hand, I want everything to be within 1 ULP and correctly rounded where possible over the sixteen digits available.
If people see sufficient need, I can make the relative error difference depend on the current mode of operations, rather than being fixed. Is these such a requirement? Does anyone really need these functions carrying thirty or more accurate digits? We're well beyond any reasonable requirement of any statistical analysis I've ever been part of or even seen.
The incomplete beta loops until convergence in all digits is achieved, so it should be fine. The normal distribution uses 1e-32 for its convergence threshold.
- Pauli
Message #13 Posted by Paul Dale on 16 Apr 2012, 3:12 a.m.,
in response to message #12 by Paul Dale
I went ahead and made the accuracy change. Double precision mode waits until the relative error is 1e-32 before terminating -- this will almost certainly guarantee a correct result to 1ULP always. I'm guessing the cost for this is one or two extra iterations.
Single precision mode remains unchanged.
I've also changed the built in solver to use the same thresholds, so it should be better in double precision mode as well.
- Pauli
Message #14 Posted by Les Wright on 16 Apr 2012, 3:38 a.m.,
You know, despite the lack of any such guarantee, I have been duly impressed at the full or near full double precision accuracy of many of the functions I have obsessively examined. That's why when I saw that F and incomplete beta seemed to be doing 15-16 digits I thought something was wrong until I caught my own error.
I should clarify that I was commenting above on F and not the inverse F. Given your "we don't guarantee full double precision accuracy" claim, I have to say that within 1 to 5 ULP in the 34th digit is pretty darn good.
Thanks for mulling over this issue for me. You are quite right about real life requirements being much more modest than the pure quest for near full accuracy. I just think it's cool when it is approached or achieved. I have been fascinated by these functions and distributions since porting the Numerical Recipes code to FOCAL some years back. I has nothing to do with real-life need. In inferential statistics, we usually are happy with the quantile or p value being computed to at best a couple or three digits so as to make conclusion about the null hypothesis. In days of yore, tables to at most 5 digits were fine!
cheers,
Les
Message #15 Posted by Paul Dale on 16 Apr 2012, 3:44 a.m.,
in response to message #14 by Les Wright
Oh, I thought you were talking about the quantile function. There isn't a lot more I can easily do with the cdf. At least without carrying more digits and then having to worry about running out of stack space -- we're close on these function, we don't know exactly how close however.
Not a terribly well respected source for this kind of code, I believe. At least amongst people who know about such things.
- Pauli
Message #16 Posted by Les Wright on 16 Apr 2012, 4:38 a.m.,
in response to message #15 by Paul Dale
So I have since learned. That said, your code for the incomplete gamma and incomplete beta bears much similarity to the NR routines. I see this particularly in the betacf() routine where you compute the continued fraction to convergence as the NR books describe--indeed, you seem to go with Modified Lentz for gcf() yet the older Wallis method for betacf() that was used in older editions of NR. I have learned over the years that the NR team has attempted to put forth as proprietary much which is already widely known through open sources.
Message #17 Posted by Paul Dale on 16 Apr 2012, 5:33 a.m.,
in response to message #16 by Les Wright
I'm pretty sure I'm using the same algorithms as the NR books & I've most definitely looked at these books -- I've got an ancient Fortran edition somewhere and my google searches for algorithms often ended up with them.
The series and continued fraction expansions for these two are pretty standard -- or at least they are what I found when I went looking. I didn't keep all the references I'd used unfortunately. As for computing to complete convergence, I do this for several other functions -- the trig functions e.g.
Anyway, if you know of a better method or algorithm to calculate these two functions, I'd definitely be interested in hearing about it (or better yet receiving code :-) They are both fairly large and neither is very fast.
- Pauli
Message #18 Posted by Les Wright on 16 Apr 2012, 6:13 a.m.,
in response to message #17 by Paul Dale
I just downloaded and flashed the most recent integration build and the inverse F CDF behaves just as I would expect it on a calculator. It is much faster than it was before, but still with the examples with which I started this thread chews on them for about 10-15 s on a calc I know is in slow mode because of older batteries. The results match the Mathematica result to 34 digits within 1ULP. LIke you say, better than anyone in real life could reasonable want.
I am a hobbyist and a duffer at all this stuff and really don't know of a better way to do this. The F CDF and inverse CDF are more complicated at every stage than the normal, t, and chi-square. With this fix, I think we should be happy it does as well as it does.
Thanks for humouring me by working on this. I know that most users are probably more interested in the stopwatch fixes.
Les
Message #19 Posted by Paul Dale on 16 Apr 2012, 6:35 a.m.,
in response to message #18 by Les Wright
Not at all, you identified a problem with the fundamental purpose of the device (which the stopwatch isn't) and it had to be investigated. Strictly it wasn't an accuracy problem, since the device wasn't returning an incorrect value but still it needed to be addressed and in doing so we discovered a true bug and I made the statistical distribution search more stable as well.
I think this is a decent win.
- Pauli
PS: I'm really only a hobbyist at this too :-)
Message #20 Posted by Dieter on 15 Apr 2012, 11:17 a.m.,
Les, I assume the error is in a wrong initial F estimate that is based on 1-p instead of p and/or n1 and n2 are swapped. The correct guess should be much closer to the true quantile. Please see my reply to Pauli.
Dieter
Edited: 15 Apr 2012, 12:22 p.m.
