UPDATE!! Re: 25C rememberss data only Message #8 Posted by Matt Agajanian on 15 Apr 2012, 8:36 p.m., in response to message #1 by Matt Agajanian
Hello all.
Well yes, this was my original update:
Turns out, after I ejected the battery pack, I found that the batteries (at least the exposed side that meets the battery contacts) has some corrosion. Although I did clean the battery contacts with the distilled vinegar, I'm inching towards the hunch that it's the batteries' corrosion that's the culprit.
But,
after a couple more days of using the 25C and a heavy dosage of heightened optimism, my 25C is an amnesiac once again, even to the point of the keycode of 40 at each program step. So, I should resolve to cut my losses. In a better light though, I should consider this machine as nice spare. It works as a 25 for everyday use but it's not a museum piece.
Edited: 17 Apr 2012, 2:20 a.m.
