Re: HP Pioneers? Message #12 Posted by Dale Reed on 14 Apr 2012, 12:24 a.m., in response to message #11 by Matt Agajanian
As I see it, the problem is that everyone is trying to make "do everything" calculators. I think what people want is "do what I need" calculators. A Do It Yourself (DIY) calculator, or a Build Your Own calculator (BYOC). Pick the functions you need and assign them where the ones you use most are unshifted, the ones you need sometimes are shifted, the ones you use rarely but want to have handy are in menus, and everything else is left out.
(Apologies to the DIY4* / DIY5 team. I have a slightly different vision of "DIY" in mind -- where instead of do-it-yourself hardware, the functionality is do-it-yourself assignable by the end user.)
As a manufacturing/process controls engineer, I would want a calculator that has signal conversions (4-20 mA, 3-15 PSI, 1-5 V, thermocouple curves, RTD curves, etc.) available unshifted; trig, log, basic financial and maybe some complex math and basic stats shifted; programmable; and all the advance stats and matrix stuff in menus or left out completely. I'd like to have control valve sizing, relief valve sizing, flow-measurement orifice plate sizing and similar equation-based functions in a built-in equation library (solvable for any variable, like the financial ones do with PV, FV, etc.).
I seem to remember that Eddie was looking to design a machine with lots of statistics capability on the primary keys. A next-gen 32E, if I recall...
All the discussions about the WP34S keyboard layout come about because everybody has a different personal priority for what should be easiest to get to on the keyboard and in the menus.
I don't want a calculator that does EVERYTHING (because I won't be able to find ANYTHING!). I want a calculator that does EXACTLY what I need, and that's easy to set up to do so (say, via some PC software and a USB port).
So right now, in order to do that, I'm building my own prototype with an MCF51JM128 microcontroller, a 4x20 character LCD display, LiIon charger, SD card, maybe USB, some EEPROM and a real-time clock chip. Maybe by the time I retire and don't need it anymore, I'll figure out how to write all that code....
But it will do WHAT I WANT.
So, HP, please come up with a calculator where it's easy for the end user to assign EXACTLY what he/she wants, with enough memory for programming, long battery life, USB and/or SD card. You'll mop up the market, because everybody's job is more and more specialized. Everybody likes to have HIS/HER OWN CUSTOM TOOL that makes the job easier.
My $2.0E-02
Dale
