Re: New version of the WP34s Qt Emulator Message #7 Posted by Nobby K. on 14 Apr 2012, 9:37 a.m., in response to message #5 by pascal_meheut
I have checked Rev. 2796.
It seemes that trunk/decNumber/decContext.h needs following fix.
Rev. 2796 version works on realbuild version.
But it does not work on QtGui without the patch.
% LANGUAGE=en svn diff trunk/decNumber/decContext.h
Index: trunk/decNumber/decContext.h
--- trunk/decNumber/decContext.h (revision 2796)
+++ trunk/decNumber/decContext.h (working copy)
@@ -29,6 +29,9 @@
/* extended -- must be either 0 or 1 [present only if DECSUBSET] */
+#if defined __x86_64__
+# define __WORDSIZE 64
+#endif
#if !defined(DECCONTEXT)
#define DECCONTEXT
@@ -43,7 +46,11 @@
typedef unsigned char uint8_t;
typedef unsigned short int uint16_t;
typedef unsigned int uint32_t;
+#if __WORDSIZE == 64
+typedef unsigned long int uint64_t;
+#else
typedef unsigned long long int uint64_t;
+#endif
/* Conditional code flag -- set this to 0 for best performance */
#define DECSUBSET 0 // 1=enable subset arithmetic
Other fixes works good.
