Re: New version of the WP34s Qt Emulator Message #29 Posted by fhub on 3 Apr 2012, 11:33 a.m., in response to message #28 by pascal_meheut
I've uploaded the fix.
Thanks!
Now it's time for Marcus to also fix his 'Compact' and 'LED' skin, because I just found out that the error is already in his old skins.
key=30,36,403,79,436, {40,77}
key=31,88,436,131,403, {49,97}
key=32,139,436,183,403, {50,98}
key=33,191,436,236,403, {51,99}
You see that for keys 31-33 the 436 and 403 are swapped, so it was in fact not your fault. ;-)
It seems that for the full key this wrong order of top and bottom number doesn't matter, but it confused your conversion routine for xskin-files and made a problem with the area for your h-shifted keys.
Franz
