How does the HP-97 printer paper feed work? Message #1 Posted by Harald on 30 Mar 2012, 4:29 p.m.
I have started repairing the HP-97 I mentioned a bit further down. I have a problem with the printer. The paper feed does need a little help by pulling the paper manually. I have taken it appart and all the gears (at least all three I can see) are ok. And the head moves as it should. But I do not understand how the paperfeed works? Can anyone help?
Also, I have replaced the gumy wheel and the cardreader pulls the card through fine. But I get an error when trying to read a card. Not sure if it is the reading or the writing that is the problem. Should it be able to read cards written by an HP-67? In that case, I suspect reading doesn't work. Any thoughts on what to check?
Cheers,
Harald
