Re: HP 15c question about [ENTER] Message #4 Posted by M. Joury on 29 Mar 2012, 9:27 a.m., in response to message #1 by nina scholz
Unlike with an RPL machine ENTER on an RPN machine disables stack lift. Therefore any numeric entry immediately after an ENTER overwrites the 'X' (visible) register. On an RPL machine ENTER is more like a 'DUP' instruction and it duplicates anything on the bottom of the stack. The reason that it *appears* to work the same way is that RPL machines have a command line which is separate from level 1 of the stack and ENTER from the keyboard effectively pushes the command line onto the stack. Any ENTER on an RPL machine with nothing on the command line operates like a 'DUP' and has no effect on stack lift.
Hope this helps. And anyone who cares to correct me or make this more understandable please jump in.
Cheers,
-Marwan
EDIT: Added below.
Here is the relevant section from the HP41CX manual (I'll try to find the section in the 15C manual and post that separately):
Stack Lift
Operations in the HP-41 C are of three types with respect to their effect on the stack. Most
operations enable the stack lift. A few operations disable the stack lift, and a few others are
neutral.
Enabling Operations
All operations on the HP-41 C other than those listed below (under Disabling Operations and
Neutral Operations) enable the stack lift. If you key in a number immediately following an
enabling operation, the stack is lifted and the number is entered into the display.
If you key in a number immediately following a disabling operation, the stack is not lifted.
Therefore, the contents of the X-register are not copied into the Y -register before the new
number is keyed into the X-register. The disabling operations are:
ENTER, CLx, Sigma+, Sigma-
Neutral Operations
Neutral operations are those that do not alter the status of the stack lift, so that whether or not
the stack is lifted depends upon the previous operation. Note that CHS and EEX are neutral
only during digit entry. When pressed any other time, CHS and EEX enable the stack lift.
The neutral operations are:
PRGM, ALPHA, ON, CHS, EEX, USER, <--, shift
Edited: 29 Mar 2012, 9:48 a.m.
