Re: HP-25 Message #5 Posted by Randy on 24 Mar 2012, 2:31 p.m., in response to message #1 by aj04062
Yes, but that might not be the best approach, especially if you don't know if it works. I have found that solder that has been exposed to battery electrolyte is bad enough, it's worse after additional oxidation from vinegar. So, my approach to Woodstock repair is to first remove all IC's and test them in a socketed board. If the unit warrants repair, I then treat the board corrosion with 100% DeOxit. Let it soak for several days then rub with cotton swabs to remove all the crud. Especially bad cases may need several treatments and some more elbow grease.
Don't get vinegar anywhere near the LED array. The assembly is not sealed and one mil aluminum wire bonds don't survive the treatment.
