Re: Which charger for a35 Message #3 Posted by Les Wright on 23 Mar 2012, 12:11 a.m., in response to message #1 by Matt Agajanian
If you have a charger for the HP67, you have one for the HP35.
I own four "Classics"--45, 65, 67, 80--but only two chargers. Used to have three, but sold one to another collector.
You are all set, provided that you have working batteries. Remember, with these calcs you need to have cells that hold at least a bit of a charge in order for the unit to work. You just can't run them off of AC without batteries. If the NiCads you get are completely flat, you need new batteries.
If you are looking for excellent battery packs, I recommend finding the seller waterhosko at that big auction site we aren't allowed to name around here. Also, Randy of FixThatCalc.com will rebuild old battery packs if you insist on a pack just like the original, but this is somewhat more expensive. (Waterhosko solders cells together and pads them with foam for a good fit--they work fine but lack the original battery case).
Enjoy your growing collection!
Les
