Re: WP34S solver Message #11 Posted by Marcus von Cube, Germany on 18 Mar 2012, 9:32 a.m., in response to message #10 by Marcus von Cube, Germany
The latest build contains a fix in the watch dog reset logic. In theory this should at least help to recover from any hangs. The calculator should show a "Reset" message after a few seconds.
I hope this helps.
Edit: The watch dog might well have been the culprit. It is served only when a heartbeat kicks in. With a full keyboard buffer, the heartbeats are ignored and thus it's possible that the watch dog isn't served in time. I may add another call to the watch dog reset routine if a valid keystroke is executed to avoid this.
Edited: 18 Mar 2012, 11:56 a.m.
