Re: HP-41CV dilemma Message #26 Posted by Matt Agajanian on 12 Mar 2012, 9:14 p.m., in response to message #25 by Luiz C. Vieira (Brazil)
HI.
I use some HP41 for years, and almost all of them run with either alkaline batteries OR N-size rechargeable ones (for about eight years, give it or take). I never had a working rechargeable pack, instead I have four non-working units. The charger for these packs varies a lot, and you are correct: the input is AC, not DC, so you have no polarity marks at all.
I'd give fresh alkalines a try. As you surely know, the HP41, along with most calculators with no 'ON/OFF switch key', has a toggle key: press to ON, press to OFF, meaning that it needs some minimum operating conditions to be turned ON. Or else it will be stuck in a C-MOS loop of some kind that does not allow it to wake itself up by the sensing of an ON/OFF toggle key. If the voltage in the battery pack reaches a 'level-too-low-to-operate' condition and it has, say, two bad cells, then the output voltage is not enough to power it up (can you measure it?). And if you use some fresh batteries right now it may not turn ON immediately. It does not mean it is broken, just that you'll probably need to let it rest for about 20 hours without the batteries (an overnight resting...) prior to give it a try. If it is a coconut, give it as much time as you can. Halfnuts somehow need fewer hours to recompose.
Hope this helps a bit... or two.
Cheers.
Luiz (Brazil)
I appreciate all your suggestions. Here's what I've tried so far.
1--Recharged the 41 for eight hours with the rechargeable pack.
2--When that was over, I tried turning the 41 on with the charger plugged in and with the charger disconnected. Both times, the 41 vdid not turn on. So, I'm thinking the pack is completely drained, discharged or cannot hold a charge.
2--I then installed the N-Cell batery chamber with fresh batteries
3--as per suggested, I tried an ON-(<-) backspace key reset. I held down both keys, released the <- and then released the ON. Did I do it right?
Although I've pressed the ON key several times, nothing has happened yet. But, the 20 hour rest I'm willing to try. Could you clarify what this means:
"let it rest for about 20 hours without the batteries (an overnight resting...)"
Are you saying I should remove the batteries and put the battery case back in the 41, let it rest for 20 hours? What exactly do you mean 'without the batteries'? Please, I need to be as specific in the directions as possible.
Thanks.
