Re: Where should I post new HP35s bugs Message #34 Posted by Jeff O. on 13 Mar 2012, 1:00 p.m., in response to message #33 by Gabor Czvikovszky
There is no direct way to attach characters to a label or variable with the 35s. You can use equations to provide prompts or reminders of the program, for example.
A001 LBL A
A002 SF 10
A003 QUADRATIC (entered as an equation, i.e., press EQN first then type it in)
A004 PSE
A005 CF 10
The above assumes you have a program you would like to label "QUADRATIC". When viewing the program listing, it will be there to tell you what the program is. When run, the program will pause, display QUADRATIC briefly then continue. Similar messages can be used to tell you what variables are going into what registers.
Sorry if you are well aware of the above.
Edited: 13 Mar 2012, 1:54 p.m.
