Re: 50G SD Card port problem Message #7 Posted by Dave Shaffer (Arizona) on 9 Mar 2012, 2:01 p.m., in response to message #3 by Matt Agajanian
Do you have any digital cameras that use SD cards? On all of mine, you have to insert the SD card further in than flush. As noted by some others, that shouldn't hurt anything. In general, the feel should be spring-loaded, and you may have to push it in farther than you think. I've never damaged anything. (the spring should get harder and harder!)
edited to replace "CD" with "SD"
Edited: 9 Mar 2012, 2:02 p.m.
