Re: New HP39gii U.S. availability? Message #9 Posted by Oliver Unter Ecker on 9 Mar 2012, 6:35 a.m., in response to message #8 by Marcus von Cube, Germany
In order to make User RPL available on these machines it would have to be reinvented from scratch.
Which is easy to do, regardless of how the command set is implemented (and how backwards-compatible it is to the 50g), *as long as* there's the concept of a stack.
If there is a stack, RPL truly begins as the most natural language, and it makes some sense to keep it. (Though it can be made nicer, better.)
