Problems building WP34s Message #1 Posted by Harald on 8 Mar 2012, 3:17 p.m.
I have installed Yagarto, minGW, activeperl and Visual C++. Cheked out the project from SVN and hit the build button in Eclipse. Unfortunately I get the folling error:
-DUSECURSES -o windows32/obj/winserial.o winserial.c
mingw32-gcc -E -P -x c -Ixrom -DCOMPILE_XROM xrom.wp34s > xrom_pre.wp34s
tools/wp34s_asm.pl -pp -op tools/wp34s.op -c -o xrom.c xrom_pre.wp34s
// WP 34S assembly preprocessor enabled: '-pp'
// Opcode map source: tools/wp34s.op (specified)
// Opcode SVN version: -- unknown --
// DEBUG: wp34s_asm.pl::run_pp: Stools/ F B'wp34s_pp.pl'
// Running WP 34S preprocessor from: tools/wp34s_pp.pl
Out of memory during request for 4080 bytes, total sbrk() is 267778048 bytes!
make: *** [xrom.c] Error 1
What is going wrong here?
Alternatively I can click on the "flash" or "xtal" make target and then get the following error - which I don't understand either, because the path is correct.
ERROR: C:\ARM_toolchain\workspace\wp34s\tools\wp34s_asm.pl::run_pp: Cannot locate the assembly preprocessor in 'wp34s_pp.pl' or './wp34s_pp.pl'
// DEBUG: C:\ARM_toolchain\workspace\wp34s\tools\wp34s_asm.pl::run_pp: S./ F B'wp34s_pp.pl'
mingw32-make[1]: *** [xrom.c] Error 2
mingw32-make[1]: Leaving directory `C:/ARM_toolchain/workspace/wp34s'
make: *** [realbuild/calc.bin] Error 2
make: Target `all' not remade because of errors.
**** Build Finished ****
