Re: 35S I & J registers Message #6 Posted by Bart (UK) on 5 Mar 2012, 5:14 a.m., in response to message #3 by Matt Agajanian
Memory management: something to remember when using indirect registers, is that memory gets assigned for all indirect registers up to the highest register used, even if the lower ones are not used. E.g. using indirect register 40 will result in memory being allocated for 0 to 39 as well. You can quickly use a lot of memory this way (write something in register 800 and do a mem check (I have ~10k free and the highest I can use is 280)). So use only the highest number really needed.
To clear indirect registers and regain memory: 1) CLVARx (BlueShift CLEAR 6): clears all indirect registers above the number entered (e.g. CLVARx 040 will clear 41 and higher). 2) Implication of (1) is that CLVARx 000 will clear registers 1 and above, but not 0 which is assigned too (and negative no.'s cannot be entered). So to get the memory back for that, you have to manually clear it by doing 0, STO I, STO (I).
Edited: 5 Mar 2012, 6:33 a.m.
