33s, 35s Clear All--How safe is it? Message #1 Posted by Matt Agajanian on 2 Mar 2012, 12:49 a.m.
Although you need to go out of your way to execute it, is this command as destructive as it sounds? I remember in the HP-65/67 days of HP that 'Clear: Program' in RUN mode just reset the program pointer to 00- and you had to be in PRGM mode for the command to erase all program lines. Likewise, in TI's days of the SR-52/56 and TI-58C/59, CP would actually erase program memory when in RUN mode and in Program mode CP would just clear the 't' register.
So, am I to understand that in RUN mode on the 33s or 35s, executing Clear: All actually wipes EVERYTHING, including all programs? Or, does this erase command take action if you're in PRGM mode, too? Is there a confirmation step to prevent you from accidentally carrying out Clear: All and erasing the whole memory contents?
