Re: WP34s low battery shut down? Message #7 Posted by Harald on 2 Mar 2012, 3:30 p.m., in response to message #6 by Marcus von Cube, Germany
Your shutdown idea will not work because the battery backed RAM in the processor will fail if you disconnect power.
I think you didn't quite get what I was trying to say (unless I am going wrong somewhere here). Disconnecting the battery is ONLY supposed to happen if the calculator is left unattended with a flat battery and not rechard for a long period of time. This is to protect the battery under those circumstances.
That is also precisely why under normal circumstances I would like the calculator to shut down BEFORE the battery gets to the level where it needs to be disconnected. Thus preventing memory loss, as the battery stays connected.
If you plan to let the calculator sit on the shelf for any longer period of time, just do an ON+STO which will create a copy of the RAM in flash. You can then remove power without any loss (except for the built-in RTC).
Yes, so that is what I would do if I wanted to leave the calculator for a longer period of time without recharging it. Because in that case the battery might disconnect itsef.
I hope this time my idea was presented in a slightly more understandable way. :)
Cheers,
Harald
PS: I think I figured out how to do this. Next I will need to build and test the circuit and find a way to integrate this into the calculator. I am thinking the space above the display (under the HP logo) is suitable. I'll keep you updated.
Edited: 2 Mar 2012, 3:33 p.m.
