Re: WP34s, has it become slower? Message #14 Posted by Marcus von Cube, Germany on 3 Mar 2012, 4:27 a.m., in response to message #13 by Cristian Arezzini
A crash is always undesirable. :-(
I don't think it's directly related to the speed update because this happens in the same way as all other speed updates, somewhere in the main loop and never in an interrupt or such. The key-up changes are not very likely to directly cause a crash either, at least not that I can see it.
Running the device at 20 MHz is obviously something different than at 2 MHz and external influences (ESD) may play a greater role. Are your batteries fresh? Are you typing fast?
If it helps I can revert the speed-up for you to test.
Edit: I've committed a special build for you to test. It does not contain the speed up.
Edited: 3 Mar 2012, 4:54 a.m.
