Re: opening HP 30B Message #3 Posted by Harald on 26 Feb 2012, 5:50 a.m., in response to message #2 by Marcus von Cube, Germany
Thanks Marcus, that worked. Got it open now.
While I have it open, is it worth adding a crystal? Does that help with any functionality other than communication (I probably won't need that, so I am not too bothered)?
I like your idea of adding a 3.5mm connector to the calculator, but unfortunately can't work out a solution that is a bit easier on the eye ;)
Cheers,
Harald
Edited: 26 Feb 2012, 8:11 a.m. after one or more responses were posted
