Re: HP-IL SCSI Interface Message #6 Posted by Eric Smith on 17 Feb 2012, 3:34 p.m., in response to message #4 by Marcus von Cube, Germany
I'm only guessing, but I think most likely it would be for the 110, not the 41/71/75. It probably translates SS/80 commands to SCSI.
The 41/71/75 don't use the SS/80 command set, they only use the "Filbert" command set from the 82161A tape drive. (It is rumored that the 82479A Data Acquisition Pac for the 71B can talk to SS/80 disks, but probably only in a limited, application-specific manner.)
The 9114 supports both the Filbert and SS/80 command sets, so it can be used on the 41/71/75 and on the 110.
