HP Forum Archive 20
DM-15CC - got it !
Message #1 Posted by Andy Lamming (UK) on 11 Feb 2012, 1:32 p.m.
My order for the credit-card size DM-15CC has arrrived. It is a neatly finished-off product - and it works ! Someone remarked the display contrast ratio wasn't too good but mine is just fine. The blister keys do have to be pushed quite positively to register. The thingy the bank gave me to access my account online uses much the same plastic blister keyboard and that was stiff at first, but with use it has eased, so perhaps it will with the DM15.
I ran Katie Wasserman's pi programme, it took 5 hours 48 minutes. Katie says the original HP-15C takes 43 hours, so it is 7½ times faster than that, but obviously slower than the LE. (I set it off at 6 p.m. & I was just ready to give up & go to sleep when it got there!)
All in all I'd say not a replacement for the desk top, but so portable it is really handy for those programmes that you enter just once and use with different data when on the move. Like times & wind lay-off in a holding pattern (aircraft).
Re: DM-15CC - got it !
Message #2 Posted by Jeff Johnson on 11 Feb 2012, 6:17 p.m.,
in response to message #1 by Andy Lamming (UK)
Cool! Looking forward to hearing a lot of feedback on these little calculators. If reviews are favorable, I'll order one when they are available again. Seems like a useful size, like in a "Go" kit for field work.
Message #3 Posted by Kerem Kapkin (Silicon Valley, CA) on 13 Feb 2012, 1:58 p.m.,
Just curious, does 15CC has the PSE bug?
Message #4 Posted by Marcus von Cube, Germany on 13 Feb 2012, 2:57 p.m.,
in response to message #3 by Kerem Kapkin (Silicon Valley, CA)
I was told it hasn't. I'll tell you when I've mine in the hands.
Message #5 Posted by Kerem Kapkin (Silicon Valley, CA) on 13 Feb 2012, 3:16 p.m.,
in response to message #4 by Marcus von Cube, Germany
It will be interesting to see if DM-15CC has the HP-15LE bugs such as the PSE. Seems like not all new HP-15C emulations has the HP-15C LE bugs for an example, I recently downloaded HP-15C emulator for iPhone called ClassicRPN version 3.2.2 by AmeloConsulting. It does NOT have the PSE bug.
Edited: 13 Feb 2012, 3:20 p.m.
