HP Forum Archive 20
WP34S nested error
Message #1 Posted by Alessandro Castellani (Italy) on 6 Feb 2012, 3:42 a.m.
hi to all,
I've tried on the WP34S emulator (22.1990) to find the minimum of a function using the built-in f'(x) command and solving it for zero:
LBL A my function f(x) that I want to study, result returned in X stack RTN
LBL B f'(x) LBL A RTN
but when I solve for B I receive the message : Nested use of solve (SLV and SLVQ), integrate, sum or product is not allowed.
Could I do this in this way or I must write a routine that calculate the derivate and then use solve on it?
thanks
Alessandro
Re: WP34S nested error
Message #2 Posted by Paul Dale on 6 Feb 2012, 3:48 a.m.,
in response to message #1 by Alessandro Castellani (Italy)
Version 2 firmware does not permit solve, integrate, f', f", sum or product to nest or call any of them others. This stems from a limitation on the number of reserved internal registers.
There are two obvious solutions here.
Code f' or solve yourself and use the built in version of the other (hint: look in the library directory on subversion for outline code for these or grab versions from the library here on the Museum).
The alternative would be to upgrade to version 3 which removes this restriction entirely. In version 3 firmware, you can freely nest and mix these functions subject to having enough available RAM.
- Pauli
Message #3 Posted by Alessandro Castellani (Italy) on 6 Feb 2012, 7:56 a.m.,
in response to message #2 by Paul Dale
Thank you very much Pauli I'll wait 3.0 release.
Alessandro
Message #4 Posted by Alexander Oestert on 6 Feb 2012, 9:54 a.m.,
in response to message #3 by Alessandro Castellani (Italy)
You can get V3 from sourceforge SVN right now! :-)
WP34S V3
Message #5 Posted by Marcus von Cube, Germany on 6 Feb 2012, 10:24 a.m.,
in response to message #4 by Alexander Oestert
We are preparing a release. Stay tuned! Walter is reworking the manual and Pauli and I are fixing bugs and inconsistencies. The cross platform emulator by Pascal is in the stage of being deployed soon, too.
Edited for correct grammar.
Edited: 6 Feb 2012, 1:25 p.m.
