Re: accuracy of integration and solve routines HP 15C LE Message #4 Posted by Marcus von Cube, Germany on 2 Feb 2012, 1:03 p.m., in response to message #3 by Jan
I'm not the most qualified to answer your question but I doubt that any reverse engineering was really necessary. The original code is run in a virtual environment as if the nut processor were still there. It's not, the instructions are interpreted by some software running on the ARM chip. This piece of software not only has to implement the processor but all of the peripherals, too, and map them to the real hardware. Here the trouble has its origins.
