HP Forum Archive 20
HP 30-B size Question
Message #1 Posted by Jeff on 30 Jan 2012, 10:14 a.m.
I have always wanted to find a financial calculator that is physically smaller.
Amazon gives the 30-b these dimensions: 9.4 x 7.1 x 1.3 inches HP says: 5.84 x 3.03 x .63 inches.
I wonder which are correct.
Also, it's about time for them to retool their ugly, tired lineup of home and office devices!
http://www.shopping.hp.com/webapp/shopping/can.do;HHOJSID=VfSRPmnQrDntnfpjJWL7QMrCqqPVLNWSpLtQg25G3PJLqcXPjhWY!677933928?landing=calculator&category=Office&catLevel=1&storeName=storefronts&jumpid=in_R329_prodexp/hhoslp/psg_ipg/calculator/Home_&_office_calculators
Re: HP 30b size Question
Message #2 Posted by Mike Morrow on 30 Jan 2012, 7:46 p.m.,
in response to message #1 by Jeff
Certainly the larger dimensions are not those of the HP 30b.
The HP 30b is one of the most satisfying products from HP Calcs in a long time, IMHO. It is the fastest HP calc ever, and although financial in flavor, it has a reasonable and useful set of scientific functions too. Its firmware does not run through a level of emulation like the HP 50g, HP 12C+, and HP 15C LE.
For speed testing, I use the common 2500-iteration Savage Benchmark. For comparison, benchmark completion times are:
HP 50g      65 seconds
HP-15C    5840 seconds
HP 15C LE   48 seconds
HP 30b       6 seconds
The result accuracy and precision for the 50g and the 30b are identical, and several orders of magnitude better than that of the 15C and 15C LE.
The 30b is about eight times faster than the 15C LE, even though both use the same AT91SAM7L128 SoC and clock speed. That illustrates the waste in time and battery energy that occurs because an emulation layer has been inserted between the original firmware and the SoC, rather than compiling new code for the SoC.
The HP 30b is a great machine, even if you don't transform it to a WP 34S.
Edited: 31 Jan 2012, 10:22 p.m.
