NoVRAM-M and NoV-32-M Message #1 Posted by cgh on 28 Jan 2012, 12:50 p.m.
I delievered on TOS a modifed code for the NoVRAM and NoV-32 built by Diego Diaz. This is the -M extension.
The aim is to use the 6 pages ROM and 4 or 8 pages RAM at almost the same time, with a dynamic configuration. Like I do not like very much HEPAX, I was finding a solution to test WWRamBox and ES-MLDL images.
I also introduced based on the first work of Diego a feature to disable the RAM read at module plug-in, but keep the write. This is useful to correct or erase a bad RAM page without loosing the others and without flashing the whole module.
Like this code is not handled by the ClonixWinCfg or ClonixCfg tools, please, read the PDF included to learn how to install them. Do not hesitate to contact me if you got trouble.
This code is NOT currently confirmed and approved by Diego but I did not run any problem while using it for one month.
I only tested these two codes (NoVRAM-M and NoV-32-M) in a NoV-32 module, but I believe that NoVRAM-M will run on a NoVRAM.
NOTE: I am not responsible for any damage on the modules, accessories or calculator which may result when using the code.
Thanks to Diego Diaz who has developpend and built the Clonix and NoV* module.
Enjoy,
Christophe
Edited: 28 Jan 2012, 12:56 p.m.
