Re: Android HP67 - v1.1 posted Message #12 Posted by Vincent Weber on 30 Jan 2012, 10:49 a.m., in response to message #11 by M. Joury
Hi Marwan,
Amazing ! I can only think that you are running a US version (are
you ?) while i'm using a French version, and that makes a difference for the Market despite running the same version.
As for upgrading, that was painful. I was running Froyo, I decided that HP-67 emulator was a good reason to upgrade to Gingerbread... so I tried with Kies, which is a real piece of crap, could never get anything out of it. I managed to find a 2.3.5 rom and upgrade via Odin, which was a breezed a worked perfectly first time.... only to realize that 2.3.5 on the GB-YP1 had a major bug: plugging in earphones would crash the device, and that was fixed in 2.3.6 !! I tried the whole day to find a 2.3.6 rom, with no succes; i was discouraged, then, playing the settings on my device I realize that OTA (Over The Air) was actually available on 2.3.5, unlike Froyo ! if you run 2.3.5, simply open the settings, "about device", the first entry is "software update" ! it worked perfectly to upgrade to 2.3.6, unlike stupid Kies.
Hope this helps, cheers,
Vincent
